05-04-2022, 03:59 PM
Can anybody recommend how to remove failing resin coating from a petrol tank. Thanks
Resin tank lining
05-04-2022, 05:32 PM
Cut a hole large enough to get your hand/arm in and pull the stuff out!
When finished solder a brass patch over the hole. https://www.austinsevenfriends.co.uk/for...h#pid39977
05-04-2022, 06:46 PM
Frosts do a stripper solvent which works!
05-04-2022, 09:51 PM
I think I used acetone when the sealant failed on my car.
06-04-2022, 05:31 PM
Thanks very much for your responses
