1/4 Taper Pin HSS Dormer RS Components box perhaps unused £4
3/16 Taper Pin HSS Dormer " " " £3
3/16 Osborne as above new £4
5/16 Taper HS Dormer new £4
Cleaveland 4mm straight £2 slight tarnish
Presto 5mm SS Hand Reamer DIN 206 - looks straight - £3
6mm Intal HSS large shank £3
7mm HS shortish £2 cant tell if taper or straight
8mm Hand Reamer straight £3
CleForge M/C Reamer Helical Flute taper shank 9mm boxed £4
11mm HS £4
straight 13mm boxed CleForge £5
and some more I haven't worked out yet - are you looking for anything in particular?
11mm HS £4
