Car type: Austin 7 Ruby 1938
The front passenger window on my 1937 Ruby gradually slips down while on the road. The main spring appears not to be broken. I am not sure of the condition of the small spring in the canister on the handle.
Is it likely that the main spring has lost some of its tension over the years?
Is it feasible to take another turn on the main spring to increase its force?
Any comments on a possible solution would be appreciated.
Car type: 1937 ARR Ruby / 1928 RF (3)
Had the same trouble with my Ruby. Fitting a new spring did not improve things, but fitting new window channel to the sides + top solved the promlem.
Thanks Ilmoro, Dave and GCD for the suggestions. The window channels are in reasonable condition. So, I will try removing the tabbed cover on the handle spindle and see what is going on in there. The photos look to be particularly helpful. Thanks for taking the time to find and attach them.
Regards
Graham.
Car type: 1932 RN saloon
I replaced the broken spring with a piece of nylon I turned on my lathe. It has been working ok for many years. A tight fit in the housing bore of course.
Hello Ian,
have dismantled the winder cover and found that I have the Mark 2 Ruby spring arrangement as per your photo. The spring has no bent end so is similar to the Ruby spring that you showed. I have managed to bend the end of the spring so that it now sits in position on that little hub as shown for the Morris 1000.
But I cannot get the spring and hub back into the cover. It seems that the spring needs to be wound a little to reduce the coil diameter to fit within the cover. Did you encounter this when you fitted the Morris 1000 spring?
Graham,
It's a while since I did mine and I can't remember any problem getting the spring back in. I coated the cup with grease, fitted the spring in its grooved spigot and then pulled it into the cup, turning to tighten the spring (against the spigot) at the same time as far as I remember.
Ian
Have struggled for another hour to get the coil spring back into the cup/cover without success. I think I have distorted the spring coil shape when bending the end and then further distortion trying to force the coil in.
Have now bought a used window mechanism from our Vintage Austin club (only $20 or £10) and will see if that will operate correctly.
Graham,
