Has anyone explained the original pits>Are the origianals cast steel? Or had it been built up by weldingI am astonished these are in short supply. just how many have the special builders ruined?
It’s an absolute bargain Tony, thank you.
Hi Tony
Now I’ve seen the price I’m more than happy with jumping in on an order. I should have a Phoenix crank by April so hope they’ll be ready by then?
Hi Tony
Will the sports ones be shorter as in the reground versions of the originals, or the same height and so not needing the guides to be shortened?
Then, if it becomes a straight choice between with either design, it comes back to the question as to whether the sports profile helps a standard engine more than it increases wear? Been discussed many times and I think the consensus was that the benefits of the open sports profile is worth using.
Andy B
thanks R
thanks howard.
thought you would like that.
tony.
A bargain, Tony. Can I pre-order two complete sports sets please?
