22-11-2020, 12:51 PM
(This post was last modified: 22-11-2020, 12:58 PM by Steve Jones.)
I know a couple of people who've fitted these, Tony, and they work well. They don't look right, obviously, and I think they're an expensive solution to a problem that doesn't exist if you renovate your original starter motor correctly but, each to his own. Never seen one fitted to a Bacon Slicer, only to the later in cab type and you do have to remember that the torque of these starters when they're activated puts a significant load on the mountings for the alloy starter motor housing, the housing itself and the crankcase.
(This post was last modified: 22-11-2020, 12:59 PM by Tony Griffiths.)
What puzzled me was that, while the 'arrangement' looks to be in line with the original design, the mounting appears to be a 'flange' rather than a 'foot'. Perhaps there's an alternative model - or might it be supplied with some sort of adapter bracket?
The mounting appears to be a 'flange' rather than a 'foot' fitting. Perhaps there's an alternative model - or might it be supplied with some sort of adapter bracket?
No, Tony. They just bolt straight to the alloy housing flange to flange as the original (later in cab housing, not Bacon Slicer). They make a range of these starters to fit all sorts of pre-war cars the only real difference between them being the angle of the flange fitting and the hole number/spacing dependant on what they're being fitted to. Walk around a VSCC Race/Speed event paddock and you'll see loads of them (although only 2 regular A7 Class 1 cars that I can recall).
Thanks, Steve, for the explanation; all is clear now - though it is an ugly-looking brute of a thing!
Well - I've run one for a couple of years on my trials Chummy - That involves a lot of starts I can tell you! I got fed up repairing Austin starters and have had no problems since. The torque starters also use far less power, which has to be a good thing when your dynamo only puts out 6 amps anyway.
Not for an original Concours car, but damn good in the ruff and tuff.............
