17-06-2020, 08:19 PM
What rating of
fuse should be used in the cut out DYN & AUX?
Thanks
Thanks
Fuses
What rating of
fuse should be used in the cut out DYN & AUX? Thanks
17-06-2020, 10:07 PM
I use 10A & 25A respectively. I think the DYN fuse was originally 6A, but these aren't readily available.
17-06-2020, 10:11 PM
Thank you David. I will ferret through my stock!
David
18-06-2020, 04:59 PM
In case it helps, I am using 5A and 25A in my Ruby cut-out.
18-06-2020, 08:42 PM
On the later cars the DYN fuse seems to protect only the summer resistor. Contray to many handbooks, and unlike earlier models, if theefuse blows dyn still works. So rating not very critical
19-06-2020, 09:02 AM
I am with Colin Morgan on this use 5amp & 25amp.
