Car type: Austin 7 RN 1931
Does anyone have a pair of door mounted driving mirrors for sale. My RN has a drivers door one but I need either a similar one for the passenger one or a new matching pair. As I’ve got older I can’t twist round to see as good as I used to!
For my Ruby I bought 2 from a cherished supplier (I think they all do them) The type that clamp over the door hinge. I threw away the door clip and filed down the end of the round steel rod that goes between the door and mirror until it was the same diameter as the door hinge pin. I put a few threads on the end to take a nut then removed the hinge pin And replaced it with the mirror or stay and did up the nut.
John Mason
06-06-2020, 02:24 PM
(This post was last modified: 06-06-2020, 04:39 PM by Steve Jones.)
+1 for the Desmo type for me as well. Have them on two of my cars. Excellent and look the part.
Given that my car was restored in the late sixties, I suspect that the Desmo driving mirror fitted to the off side may be a genuine one.
Car type: Box & Special
Whilst discussing mirrors, it may be worth considering the position of the mirrors. If you are using hand signals, your arm can block out the view in the mirror if they are too low. No such problem if you are using indicators.
Desmo mirrors on my Box are very good.
All the best,
Colin
What a glorious spot Jim. Where is it?
