08-05-2020, 05:10 PM
Does anyone supply new rubber grommets to sit between the chrome bezels and the painted dash panel on Ruby’s please?
Ruby instrumentation - rubber grommets behind bezels, supplier?
08-05-2020, 05:32 PM
Thank you Jim,
I have tried these but they are too round and way too shiny - I think the originals were more like a large thin rubber washer.
08-05-2020, 05:51 PM
(This post was last modified: 08-05-2020, 05:52 PM by "Slack Alice" Simon.)
Cut them from silicon rubber sheet?
If the size is known, and enough people want them, I am sure the people who make the gaskets could do them. If you tell me a size, I can do a 1mm thick one by hand for you to try. Simon I only have terracotta colour, though. Would be worth a try maybe?
08-05-2020, 06:04 PM
Hi
I just did a search on "Austin 7 instrument to dash panel seals" and a number of sites came up. I got a set this way a few years ago, but haven't tried them out yet otherwise I could recommend a particular supplier. They looked Ok at the time. Regards Peter
08-05-2020, 08:30 PM
I was thinking square section like this:
https://www.ebay.co.uk/itm/293153365096
08-05-2020, 09:02 PM
Might these suppliers have something?
http://www.jdo1.com/bezels_gaskets.html Low down this page: https://www.autoelectricalspares.co.uk/b...s-68-c.asp
09-05-2020, 07:33 AM
The sponge cord might be the right stuff that JD does.I think I have used that as the sealing ring between glass and bezel before,available in 2 or 3 mm dia.looks like o ring but much softer. Can't think of the seal suppliers name at the moment,C O H Baines is one.
09-05-2020, 12:02 PM
I have been known to use a suitable rubber band. They do perish quite quickly, but it won't matter if you don't disturb them.
Robert Leigh
09-05-2020, 12:23 PM
Ruairidh, If you go onto ebay, Video Drive Belts you will find some that will do the job.
Bill retired T V Engineer. |
