  • 0 Votes - 0 Average
Early clutch release bearing
    Started cleaning up all the clutch bits for the AllAlloyCup.
All seems OK but the early type release bearing may not be quite right ?
There’s a fair bit of slackness in the part that the levers bear on? It spins ok but
I can move it a few mm?
Is this normal or should it spin quietly like a wheel, or engine bearing?.
It also seems hard to find a replacement?
Only one supplier lists it but at £125!
I’m new to Austin’s so please pardon my ingnorance
Bill G
(09-11-2017, 07:27 PM)AllAlloyCup Wrote: Started cleaning up all the clutch bits for the AllAlloyCup.
Bill G
Seven Workshop,around £42
Thanks,
Actually I tried getting on their website today
But could not get access, will try again!
Thanks Bill G
The four speed release bearing will work on the three speed clutch and gearbox if you use the four speed style clutch levers. Does save having to find a decent finger basket/ cut 3 new slots in an existing basket.
(09-11-2017, 08:16 PM)AllAlloyCup Wrote: Thanks,
Thanks Bill G
Was over there today -- Jamie says his internet connection is down so maybe best to give him a call.
Charles -- Norfolk
His site is back up - hooray!
