Car type: '27 Chummy, '34 Special, '50 Traction Avant
27-11-2019, 02:55 AM
(This post was last modified: 27-11-2019, 02:57 AM by Mark McKibbin.)
I have reconditioned the drag link with a kit but there seems to be play when the spring compresses. See video
Mark
Mark,
Have you fitted the shaped disc inside the cap and some packing washers to compress the spring (all of which make it difficult to assemble without using a sash cramp).
Tony.
Yes and a b*gg*r of a job without a long cramp- I have one which fits on a length of water pipe.
If you do not have a die and odd rods two relatively inexpensive threaded rods can be used to fabricate a clamp.
With that amount of play I think you are missing one of the cups that go around the ball pin.
Has the one that lives in the tube escaped down the tube?
Car type: 1932 RN saloon
Mark, It is a swearing -inducing job but I use a flat bladed screwdriver just large enough to fit in the end hole, even when the holes in the rod end and rod have only half the holes visible. At that point, push the blade into the half hole and twist through 90 degrees and at the same time push the rod end bolt into the now circular hole. Hope that works for you.
