Advice on fitting the Silicone Valve Chest Cover
What’s the best way to fit the new silicone valve chest gaskets?
With the cork gasket you had to chamfer the gasket to fit into the cover then cement it in place before sealing it when fitting.
Do I fit the silicone gasket dry or greased or sealed??
Any advice is more than welcome.
Thanks
I do the following:
Degrease the groove. Put the gasket in position. Secure each corner with little dob of superglue. Clean the mating surface on the block. Fit and forget!
Rick
In deepest Norfolk
Wink
Thanks, followed your advice and put a weight on the cover until the glue had dried, now it's fitted.  Wink
A lot easier that playing around with the cork gasket.
