Gear box oil level
Hello
i bought my first austin seven with a 3-speed box and an eltos remote gear change. I tried to check, if i have enough oil in my gear box. If I open the big screw (1) I can just feel gears. How can I measure there the oil level?
thanks for any hints.
regards Siipo
Look on the opposite side of the gearbox and you should have hole in the floor and a square filler for the gearbox.
The oil should reach the bottom of the thread, no more or you’ll likely find your clutch slipping!
Its a three speed box Ivor so your advice although correct for a four speed is not right in this case, I would also add slightly less that reaching the bottom of the thread. With a three speed box the engine dip stick usually can be used for the gearbox level too, however in this case it appears we have a special so who knows which engine and dipstick is fitted. Probably best to drain and refill with the correct quantity then see if it can be measured with a dip stick through the hole.
My mistake, I thought it was a four speed!
The early engine dip-stick also works in the gearbox.
Normally this is done through the filler hole but may not be possible with the remote gearchange.
Drain box
Measure oil.  Make up to recommended amount -take advice on this.
Refill.
Check with suitable stick and mark for reference.
