Car type: 1929 special
Car type: 1934 RP Saloon
Looks to be raw water cooled using a Jabsco type pump (parts readily available today). Nice bronze manifold with integral water injection point for the water cooled exhaust outlet.
As it is raw water cooled (the river or sea water passing directly through the block) I would think it would be best for a river boat due to potential corrosion issues.
Interesting engine.
The pump mounting on the front of the magneto shaft is reminiscent of the water pump arrangement on a blown car. The extended starter handle housing looks similar as well
Charles
The crankcase of the Military cars also have the same water pump arrangement which I noticed when looking through the Military Parts List in the Archive the other day..
I always think of the military vehicles being after Austin went over to coil ignition. The parts list 1163 shows a water pump but with a coil engine and no indication where it might be driven. The drawings indicate an alternative shape to the front of the crankcase, but no matching nose piece. Come to that there is no impeller for the water pump. I have always had my doubts about the accuracy of these parts lists.
