08-08-2018, 10:17 AM
Can anyone please tell me the overal height of an RP please. Am looking at a box trailer to buy so need to know if RP will fit. I've found all of the other dimensions but not the height. Thanks
A7 RP Height
08-08-2018, 11:38 AM
My RP stands 62" max. I'd allow at least another three inches for fresher springs and bouncing en route.
We regularly transport A7s in a medium-roof Transit, which annoyingly has 61" clear under the door catch, so I always fit a pair of tyre-less scrap wheels on the back axle of saloons.
08-08-2018, 12:48 PM
(08-08-2018, 11:38 AM)Martin Prior Wrote: My RP stands 62" max. I'd allow at least another three inches for fresher springs and bouncing en route.Thanks Martin, just what I needed to know. The trailer I'm considering is 5ft 7" so should be about right. My RP is some way away from home at the moment having work done otherwise I could have gone out to the garage and measured it.
08-08-2018, 02:39 PM
(08-08-2018, 10:17 AM)AmytheAustin Wrote: Can anyone please tell me the overal height of an RP please. Am looking at a box trailer to buy so need to know if RP will fit. I've found all of the other dimensions but not the height. Thanks Mine is 613/4 inches - your 5' 7" sounds OK. The other thing you need to be careful of is the width because it will lean quite a lot going round corners. I would suggest at least 6' is required.
08-08-2018, 03:04 PM
(08-08-2018, 02:39 PM)Nick Turley Wrote: The other thing you need to be careful of is the width because it will lean quite a lot going round corners. With all due respect to Nick, our Transit is a gnat's whisker under 5 feet wide internally at RP gutter level and rolling has never been an issue.
08-08-2018, 04:30 PM
No worries on the width guys......trailer is 6ft 2" wide, internal, so plenty of room.....
