If you use a single point cutter pushed down against a stop, can put a dob of solder on the shaft for a snug fit and little tendency to chatter.
As previous considerable caution is needed with the steep cutter or the seating is moved irrecoverably too far up the original valve face.
About the only way to absolutely check concentricity is a neat fitting dummy valve machined in one setting or a dial gauge on a neat fitting mandrel.
For other cars I have made a range of dummy valves from mild steel threaded onto rods and turned. When used as a lap restored between centres or equiv.
Jeff,
checked my notes today and the plated valve was done 25 years ago and the company no longer exists But another company we used to use does.
They are D K Holdings in Staplehurst, make sure that you get a fairly course grit otherwise your arms will ache unnecessarily.
Hope this is of help,
Robert.
