And now for something a little different.
And now for something a little different: as the 2022 Austin Seven Centenary celebrations approached, several original, high-quality printers' engravings from 1929 came to light. These were used to produce large banners for part of the exhibition, with the originals now stored safely in the Austin Seven Clubs Association Archive. The variety of registration numbers used is interesting: OF 6209 is from Birmingham and dates from late 1929; RY 3121 is from Leicester and would have been issued late in 1926 or early 1927, and PY 412 is from Yorkshire; the PY began in August 1923 and would have been on a car registered in that year. Here's the first one.
If you'd like a copy of this as a small print, a poster of any size, or of other posts of restored covers, go to my website https://www.lathes.co.uk/austin7/page5.html and scroll down the page; you'll find the two images. Click each, and they will automatically download as files ranging from 2.5 to 3.5 MB each. On a PC (as you probably know), look to the right at the top of the page, and find the download arrow, click it, and they'll go into your downloads folder. You can then print them out. If you'd like a larger print (up to 2m high look good from a distance) pop them onto a pendrive and take them to your local graphic shop.
I've set many of the carefully restored images here https://www.lathes.co.uk/austin7 so that clicking them downloads high-resolution copies. Note that at the top of each page is a set of hyperlinks that take you to many other pages.
