An interesting little item: the "Vislok" triple-locking nuts were widely advertised during the 1920s, but until the other day, I'd not realised they were available in a version for the Seven. As we all know, standard wheel nuts have a tapered end; one wonders if the flat base shown was intentional, or just an artist's error.
This looks interesting. Over the years I’ve been involved a few times in theory of why wheel fasteners come loose. If anyone knows more of these I’d like to know.
25-01-2026, 05:19 PM (This post was last modified: 26-01-2026, 06:03 PM by Tony Griffiths.)
I've dug a little deeper and discovered that the VISLOK lock nut was patented in 1910 by Walter Clay Peters and designed to eliminate the need for spring washers, split pins, or a second locking nut. The locking action took place within the nut itself: although the two parts could turn slightly relative to one another, they could not separate. This removed any excuse for the fitter to shorten time to a tea break by searching the floor for a missing washer, struggling to line up castellations for a split pin, or wandering off to stores for the “correct” size.
The original patent drawings show that it was more than just two nuts threaded together, but a carefully engineered, surprisingly complex design (well, it appears to me that way...). VISLOK nuts were later used in aircraft work, so they must have been trusted for safety-critical applications. One wonders — were they ever used as the ‘Jesus nut’?
hmm, doesn't that mean that if you put the spanner in slightly the wrong place you could mistakenly lock the nut away from its intended surface and in any case the original torquing of the nut itself is reliant on just 2 turns of thread? Given how things are butchered I wonder how well it would work away from that first clean (knowledgable) assembly.
Well, yes but with any fastener system you have to assume the user knows what he is doing. I agree about the number of threads. Ideally you need at least 5 full threads, and other diagrams of this system I’ve found show just that. Perhaps the graphic artist wasn’t much of an engineer
26-01-2026, 06:33 PM (This post was last modified: 26-01-2026, 08:06 PM by Tony Griffiths.)
From the Science Museum:
This lock nut, known as the "Vislok," is in two inseparable parts capable of relative rotation, as patented in 1910 by Mr. W. C. Peters. The upper part of the nut has a conical seating in the lower one, which dovetails into the undercut edge of the upper part. A line is stamped across the junction of the parts and the whole nut tapped as usual.
When screwing onto the bolt, a spanner rotates both parts together in line. To lock the nut, the top half is rotated relative to the lower. Not only does this give the wedging action of ordinary double nuts, but it introduces also a radial pressure due to the wedging of the dovetail; it is claimed that this renders the nut immovable. The thread is not damaged, and the nut can be used repeatedly.
