Afternoon all,
Some photos of my modified con rods for my splash fed engine build. Extra oil holes through the flanks and shells plus clearence for the Newman cam. The big end bolt heads have been dressed down as well but the crankcase wall still required some slight relieving.
Many thanks ro Terry G. for all his much appreciated advice.
18-01-2026, 07:18 PM (This post was last modified: 18-01-2026, 07:23 PM by Paul N-M.)
Hi Steve, Phoenix 1and 1/2". I dont think there are quite the same clearence issues with the smaller crank. The Newman cam was certainly an issue though. All rods were machined to the worst case to keep weights same.
Oh yes. The drillings are roughly at 35 degrees to meet near the middle of the shell. You will have to determine what suits your particular rods. All drillings and shells carefullu de burred.
Is this a new design of Phoenix rod Paul? I must admit I haven't seen any new ones for a couple years but the two sets I have in my engines are horizontally split rather than diagonal like the Tony Betts and Hadley rods.
Yes, the last set i used were horizontal but now they supply 45deg split. Actually I think there is scope for our suppliers to improve the crank/rod set design if shells are being used. The shells are mutch narrower than the rod bog end, I think they are Hyabusa, so the rod shoulders could be narrower with the journals shorter to suit. If this was possible there may not be the need to machine to avoid the camshaft. Just a thought. No issues if using a reprofiled factory cam.
Clearance to the cam is, I guess, why Austin never attempted a 1 1/2" shaft for the later 3 main bearing engine.
The shaft itself is no problem, but with the additional offset of the big ends fore and aft, the rod design would have been somewhat compromised in order to clear the cam lobes - even with a standard cam - ultimately negating the benefits of the stronger shaft.
Paul, I'd be very interested to learn what that Hayabusa(?) shell is, if you have the info - is there a number marked on the back?
As for the width of the shells, obviously I have no measurements - but keep in mind that one of the main benefits of a modern shaft is the greatly increased corner radii on the journals, which are powerful juju against fatigue crack formation. The shells must clear these radii or will fail in short order, so you must expect to see at least 3/32" or 1/8" empty space either side of them. If much more than that then you may be right; perhaps the parts have been adapted according to availability of replacement shells.
The bearing area of the shell should be more than adequate as long as alignment and oil supply are sound. Some of the big ends on the market today, even for quite high performance cars, are shockingly slim. White metal is one of the weaker bearing options but even so by comparison the original Austin design has acres of area. I've always imagined this was to mitigate the rather variable results of hand scraping.
