Gear Lever on 1929 3 speed crash gearbox
I now have the inner works of my gearbox working and I can engage 1,2,3, and reverse.   now I'm onto fitting the gear lever and the gearbox top cover.
With the cover bolted down I can get 2 and reverse but not 1 and 3. Its almost as if the lever wont pull the selector fork on either side far enough down it hits the edge of the hole in the top casing.
A couple of things.
I realise i have the lower ball seat bh118 in the wrong place i can fix that easily
The slot machined in the ball on the gearstick is a horrible mess, im getting a replacement
the locking screw bh119 was missing so I machined down the end  of a 1 inch long 5/16 BSF machine screw. Is 1" long enough? does anyone have one they can measure?
the top cover isnt original I had 2 came with the car one for the old type gear lever and one for the later 1929 gear lever. The later type top cover was knackered so I bought a replacement second hand As i understand it they are interchangable, is that right?
I have re-shimmed the selector rods in the main box. they are tight in and the gears seem to mesh ok, Could i have got that wrong and need to move the selector rods further towards the bell housing?  (please say no Ive had the front and rear covers off the gearbox 3 times so far and if i can possibly avoid it I dont want to do it again. Sad
Any other clues?
This is the locking screw. The overall length from underside of head to tip is 3/4" with the threaded portion being 1/2".
Much obliged  Big Grin
Thanks for the above posts. They gave me the inspiration to reduce the excessive sideways movement of the gear lever on my RN.
The slot in the ball had little wear, but the unthreaded section of the setscrew was badly worn.  I found a spare bolt with the correct thread and modified it to replicate the setscrew, except having the unthreaded section a little oversize. It's made a huge improvement without the need to weld and mill the ball.
