If anone f looking for a puzzle to sove on a cold wet afternoon perhaps try to tell what this fits:
https://www.ebay.co.uk/itm/257283255848?...R_6JwIz1Zg
I have tried to use previous info here:
https://pub25.bravenet.com/forum/static/...4&cmd=show
But I can't work out from the info supplied if it would fit an RP? Info on length suggests not and part number is incomplete, but not sure of that is because lengths are being measured from different places.
Thanks
Andy
10-01-2026, 06:39 PM
(This post was last modified: 10-01-2026, 06:43 PM by Chris KC.)
A puzzle indeed.
At 22 5/8" though it sounds like a Ruby column (earlier Ruby, as they changed shape completely for later models).
This is (should be) measured from the end of the outer column to the top of the crenellated bronze/ brass housing into which it is screwed.
An RP column should be 1 5/8" longer, as it had a flatter steering wheel compared with the deeper Ruby one i.e. the wheel ends up at the same height and the column length was adjusted to suit the steering wheel.
If it's a Ruby column you want I've got one you can have for a tenner if you come and get it...
p.s. Of course you CAN fit a Ruby column in an RP if you really want to; with the correct steering wheel on it will simply sit a little lower. I know this is perfectly driveable because that's what's currently in my own RP - though I plan to change it as soon as an opportunity arises (there are more pressing tasks on the list). You might struggle though if you want things like GAS - IGN control levers to work.
That's an early Ruby type column. Note the two threaded holes for adjusting the outer column and the split brass tube at the bottom to enable clamping of the trafficator switch and horn assembly.
Thank you all. I knew the answer would be here
