Another real bargain of a lathe
The seller is requesting a £50 donation to the Prostate Cancer Charity. It's an Atlas 10-inch bench lathe with compact dimensions, a neat, built-on all-V-belt drive countershaft with 16 speeds (including backgear), a 5-inch centre height, about 24 inches between centres, backgeared and screwcutting. It appears to have two 3-jaw chucks, a faceplate, some changewheels, a 4-way toolpost, and a single-phase motor - and perhaps even a milling slide.
You can read all about this versatile lathe here: https://www.lathes.co.uk/atlas
It will appear exclusively on Friends for a week before being advertised more widely.
Here's what the seller has to say:
I was recently given this lathe, but as I already have a lathe, this one is not required. Hence, available for collection only from Abergavenny for a donation of £50 to a suitable charity, e.g., Prostate Cancer UK.
Please note: there is no chuck key for the chuck holding the piece of aluminium. There is a new chuck key for the two smaller three-jaw chucks. There is no four-jaw chuck, but there is a faceplate, drill chuck (no key) and what could be a vertical slide?
Before taking the lathe apart to transport it to my place, the lathe started up and although there was gear rattle, it seemed to spin fine.
Email Mark on: dvarkholm@yahoo.co.uk
