A decent Blacksmith should be able to get that straight enough to use again.
Another option might be a 15" 2CV Wheel with the centre removed.
I had 15" wheels built for my 'Ulsteroid' on Austin centres by Turrino Wheels turrinowheels.com who are based slightly west of Wansford on the A1. It may be worth sending a picture of your damage and asking whether they could correct it. A rebuild with new rim and spokes on my old centres was around £300 per wheel. If they will repair it should be less.
Hi Henry
I’m sure you’ve tried Nick Mouat ( mouat.nick@gmail.com)? He made a pair of 18” wheels for me recently from centres I sent him. Good job.
Car type: Austin 7s
Still searching! Nothing suitable has turned up yet.
Dickie is right, I’ve straightened out worse than that with a hide mallet!
Mike’s supplier in the ‘States, mentioned above has 15 x 3 on his list, so there may be an option there.
My local tyre place in Rugby has a special machine for straightening alloy wheels which have been damaged by a pothole. Might be worth trying them for that rim.
