01-06-2025, 05:38 PM
(This post was last modified: 01-06-2025, 05:38 PM by Howard Wright.)
Hi Alan
I believe 1” solid steel bar has been used in the past. Getting the correct specifications for a tube will be difficult as it is very thick walled. I suggest you get a length of bar, assemble the cross shaft without bolting in the cotters, see how long it needs to be and cut to length. You will then need to grind or file cotter grooves.
I could grovel under my cars to check the length but it’s Sunday evening. If no one comes up with the correct length I will measure it tomorrow.
If they are the same length, I can measure a Ruby version as mine is on the bench.
Jamie.
Hi Jamie / Alan
Unfortunately they aren’t the same length. The pre 1930 short wheelbase brake shaft sits closer to the cross member than the long wheelbase cars and is slightly shorter.
Hi Alan and Jamie
21 5/8”
If I were you I’d buy a length of 1” bar (EN8 should be OK) slightly longer and cut to suit. As far as I can see it doesn’t matter if it’s a bit longer as it’s not going to foul anything.
I think I might be able to help in your search, Alan, but I won’t be able to check until the weekend. If you are still in need then, I’ll see what I can turn up..
I believe Tony Betts of County spares used to supply these.
Car type: RK Saloon 1929
thanks everybody for the advice
