Spark plug sealing to face of cylinder head
I noticed bubbles around the base of two spark plugs recently when, due to an oil spillage, a lake was formed in the plug holes of cylinders 1 & 2. I assumed the washers were squished and so changed to new plugs. The result was the same, bubbling around the plug base. Closer examination of the well into which the plug sits on the HC head I can see that the seat is gribled and needs refacing, much as a tap washer might need to stop it dribbling.
Is there a tool or method of correcting this please? I dont have a mill and would prefer not to remove the head if at all possible.
Thanks in anticipation of your suggestions and remedies
Jack
Idea Idea Idea
This discussion might help to provide a solution: https://www.mtfca.com/phpBB3/viewtopic.php?t=34939
I have used copper sealing rings to resolve this in the past.
Thank you both, I will use a thread sealant then rather than try to clean up the plug hole face and a copper washer rather than the steel laminated washers supplied on modern plugs.
Ta Jack
