Car type: 1937 Austin 7 special
After many delays i have finally managed to get my special on a road test today but it has a miss fire on number one cylinder. I have taken all the plugs out and 2, 3 , and 4 are sooty as it is running a bit rich but number 1 is wet but no soot however there appears to be a nice healthy spark at the plug . When i touched the exhaust manifold number 1 doesnt appear as hot as 2,3 and 4. I know it will be a process of elimination and any pointers will be most appreciated.
If you have a starting handle check compressions by turning the engine. If number one is low compared with the others check for full valve travel. After an engine has been unused for a substantial time it might have a stuck valve. I have cured this with the valve cover off and a substantial screwdriver poked into the offending spring and pushing it down with the engine running. Probably necessary to hold screwdriver in place while someone else starts the engine.
Thankyou Robert. There is no starting handle. Its a newly rebuilt engine , new pistons ,crank and rods and running an 1 1/4 SU on a log type manifold. It seems to tick over ok and the mis firing occurs once i pull away and under load
Car type: Type 65 1934 + RP 1932
If the compression on number 1 is good I would suspect the spark is failing under load. The condenser appears to be working on 2,3 & 4, so I would look for a cracked distributor cap, defective plug lead or spark plug with high resistance.
