My 1933, 2 bearing Engine is running fine.
However, on tickover, I get a random 'tinkle' noise, appearing to be somewhere from front of engine. Pretty sure it's not preignition, still there when I fully retard A/R lever. I know its a long shot, but anyone any idea what it might be.
24-09-2023, 08:58 PM
(This post was last modified: 24-09-2023, 09:40 PM by Chris KC.)
I haven't heard 'pinking' for years, modern fuels don't seem to do it. It would normally happen under load e.g. slogging up a steep hill in top and sounded rather like a wine glass breaking. I'd suggest to start by eliminating simple things like the fan assembly (try removing the fan belt) or starting handle.
Could also be the fan. The bush doesn’t have to have much play in it to make a noise. Takethebelt off and see if the noise goes away.
It could be the bendix spring on the starter motor not seating properly.
Car type: Austin 7 Boattail 1931&1929
My best bid. Too much backlass in cam/dynamo gears. If it is less tinkling with full/winter charge .
Car type: 1933 RP Standard(ish) Saloon
First, take the fan belt off. If it's still tinkling then it's likely to be the starting handle. Take off the handle. If it's still tinkling, buy ear plugs.
My '35 APD had exactly the same problem. Cured by replacing the fan belt pulley shaft/bearing with a less wobbly one.
Rick
In deepest Norfolk
Mine was also the starting handle brass bit vibrating happily to itself.
Not many things on an Austin 7 that can be fixed with a bit of sheep's wool taken from a barbed wire fence
