22-09-2023, 09:27 PM
My 1937 Ruby has the rear window drain channels fitted and intact but there are no connected drain tubes. Connecting the drain tubes is obviously a straightforward task.... But where do the tubes exit the rear quarter panel. I am assuming through the bottom of the panel or even the B post, but if this is the case my car appears to have no hole. Can anyone appraise me of where it should exit?
Thank you
Ian
Thank you
Ian
