Dynamo drive gear
Does anyone know if there is a reliable source of dynamo drive gears?
Cheers Denis S
Funny you should ask as I wanted to ask if anyone knew if these were genuine Austin parts and therefore presumably OK.
https://www.ebay.co.uk/itm/334971273218?...p_homepage
Sorry, I should have clarified that the ones I am querying are actually distributor drive gears.
I believe our regular trusted suppliers have good replicas of the distributor drive gears but cannot find any dynamo drive gears.
I have a dynamo that has been refurbished and tested but the drive gear was not included and needs replacing
Hi
Dave Dye, AKA ‘Austin in the shed on this forum’ supplied me with a set of crank, cam and distributor gears about two years ago. They are first class and going well after 4000 miles.
