04-09-2023, 09:44 AM
Is there any reason the top dynamo fixing can't be a stud rather than a bolt?
The thread in my dynamo housing is partially stripped but OK towards the very bottom. Ideally I would fit a Helicoil but a kit is around £25 which is a lot for something I'll probably only use once.
I was thinking of using a stud so that I can run it down into that part of the thread which is OK and probably also bond it in place with something like Screwloc or epoxy.
Any reason why not?
John.
Any reason why not?
John.
