Car type: ARQ Ruby
As per the thread title,
Looking for a 3 Bearing Crankcase to help out a fellow Austin 7 owner in Italy, Yes I have asked before, but this time
his C/Case is damaged beyond repair !!!!! Rod though the side, and no, the local welder messed it all up, so s-crap .
I think I may be able to help, thought the one I have has a foot knocked off. I have the bit, so it will need welding (though perhaps not by his local chap) IT may not be your best option so let us see what other offers you get?
hth...
HUgh
I've seen patches bolted over holes in crankcases, and still apparently giving good service; but it rather depends on the hole. The only time I put ironware through the case the destruction was fairly comprehensive.
Car type: ARQ Ruby
Thanks Ruairidh, my friend Andrew and link to our Italian friend, should be giving you a call soon to discuss further. cheers Alan.
Dave.
Re: Laser welding
Yes, I have on an Ulster crankcase. No distortion at all but somewhat eye wateringly expensive.
