Item sought for the Archive
Does anyone have a copy of the VSCC Bulletin, Summer edition 2008, No 260 that they would be prepared to donate to the archive, please? There is an Austin 7 based article that I would like to add to the colleection...
thanks
Hugh
Are you wanting a full copy of the Bulletin or just a copy of the Norman Prince article, Hugh?
If that is the issue with the Norman Prince article, then I gave you a copy of this issue a couple of years ago, plus the next one which had a follow-up article on his post-Austin experiences. They should be inĀ  the Archive somewhere, Hugh.
Doh!
You are quite right Mike.. I was tidying up my email inbox which is beginning to threaten my capacity limit and was clearing out large emails. Yours had images of the Article and my request was 'fired from the hip' as one might say..
Note to self: check first... :o(
Thanks for the offer Steve...
Hugh
