Car type: Austin 7 Ruby 1937
Hi gang
I have the rear axel apart and I want to change the felt washer for the half shafts
Do these need to be greased. Or go in dry?
Same question for the felt washers on the wheel hubs.
Many thanks
Felt washers need to be soaked in oil before fitting. Submerge them in a pot of engine oil overnight before fitting them.
Some rebuilders have used tallow to soak the felts as this was apparently used in the factory.
Car type: ARQ Ruby July 1936
I soaked the felt seals on the rear axle and the rear hubs in Tallow prior to installation but it was not long before they were leaking oil.
I stripped them out and replaced them with modern lip seals on the half shafts and hubs, touch wood to date they have shown no sign of leaking, hope I am not speaking too soon ???
Oh thanks
I'll look into that.. interesting history.
I’ll second that, the lip seals slot straight in and as long as the running surface is nice and clean, no leaks!
23-01-2023, 01:51 PM
(This post was last modified: 23-01-2023, 01:51 PM by Stephencrisp360.)
ok.. taken on board... will order some new fangled bits.
Out of interest what do we believe the life to be of each option?
