15-10-2022, 12:08 AM
I’m looking for a starter pull cable if anyone has one available
Thanks
Thanks
Ruby Starter Pull Cable
Thanks
15-10-2022, 08:14 AM
Bicycle brake cable, perhaps?
15-10-2022, 08:26 AM
It’s the knob assembly at the dash end that’s the problem
I’m sure something will turn up ?
15-10-2022, 01:42 PM
k8207418, What is the problem with your cable pull. When I first acquired my Ruby the knob assembly was tight to pull and had to be pushed back in by hand. On removing from the outer I found a bodged attempt to solder a new cable to the shank of the knob. A bit of work with a file soon removed the access solder and it has worked correctly ever since.
John Mason.
15-10-2022, 02:15 PM
The pull I have is not from an A7
I’m looking for an original design that fits the dash that’s all
15-10-2022, 02:19 PM
Most motor factors will sell you a ready built up cable and outer that you can cut to length. An example: https://www.beal.org.uk/automotive/vehic...cable.html
You then cut off the plastic handle and glue on a more appropriate starter knob. I've done that a number of times for starter or choke pulls and all work fine. Steve
15-10-2022, 03:34 PM
Hi
Is this what you are looking for? I don’t know if it is Ruby or not but it matches the photos on your other thread. Note the cable needs replacing. If you’re interested send me your address via a pm and I’ll post it to you. In return £10 donation to MacMillan cancer fund please. Cheers Howard D375FC29-84D8-4647-9194-6E6582F9F7F0.jpeg (Size: 201.08 KB / Downloads: 121) 56EDD6AA-68AA-4862-B586-C296194971C0.jpeg (Size: 139.91 KB / Downloads: 122)
15-10-2022, 03:57 PM
That’s Great
Many thanks
15-10-2022, 04:57 PM
the starter pull of a 2 CV is similar and does not need that much modification this (https://www.franzose.de/en/Alle/Alle/Anlasser/ANR14588/) is a link to a supplier in Germany but there should be a Citroen 2CV specialist within the UK as well I'd think . BTW the 'D' stands for "demarreur"... gives a little French touch to your Ruby...
