11-05-2022, 08:28 PM
(This post was last modified: 11-05-2022, 08:38 PM by Andy Bennett.)
Further to the earlier post which covered the question of the thermosyphon process, I have found the step by step pictures I took of the warming process.
The heat patterns are relative rather than specific temperatures but here goes step by step with timings shown. I have to do in 2 posts as i appear to be limited on pictures per post:
Engine cold:
Engine head warming but no sign of any heat going into radiator
First sign of some heat travelling into radiator
First sign of real heat into top of radiator by the inlet
more heat into top of radiator but rad still cool
heat beginning to travel down height of radiator less than 4 minutes after start up
more to follow
next picture
top of radiator temp stable but heat travelling down suggesting thermosyphoning running now
30 seconds later more heat at the base of the radiator
again a few seconds later with the engine hot but the radiator still not at full working temp and still relatively cool at bottom
30 seconds after last radiator picture and the heat pattern is relatively stable and remained like this with the radiator core middle at 86 degrees
engine now at even temperature, just over 5 minutes from start up
All of course at a standstill so not real driving, but temperatures appeared to stabelize at the 5 minutes or so point from start up at a relatively low 17 degrees ambient.
Engine cold:
more to follow
next picture
