Car type: Austin 7s
I'm working on a modified Austin/Reliant hybrid 3 bearing engine at the moment.
I'd like to replace the centre main bearing shells with new.
I have just removed worn Vandervell 1724 shells which don't look like Austin or Reliant.
Does anyone have access to a Vandervell catalogue?
I'm interested to know what vehicle they originally came from?
Thanks in advance.
Phone Gosneys in Romford. If they can't tell you from the reference number, you'll struggle to find someone who can.
Re. the Morris Minor possible contender, How wide is the shell? Early ones were 1.187" wide. Later 1098cc ones were narrower. Can't remember the width but I have a set of them here which I could measure if it is useful.
Car type: Austin 7s
Austin and Reliant shells are 15/16" wide. BMC A series seem to be 1 1/16" wide. Both are 1 3/4" dia.
Not thought about these for a great many years, but have a memory of Metro Turbo bearings being considered special, and necessary, but not sure if that's a main or big end, or anything else, but its another guess at what it might be.
I used metro bearings for a long time, they lasted about
2 years before failing.I just dropped the sump and changed them.
Eventually changed to 2 bearing crank.
Andy
Just curious but are all or any of these white metal? The early 803cc were notorious fro origianl w.m. big end failure, but main loads are less severe.
