14-03-2018, 09:10 AM
little raised triangle on underside of spider of 20"; nothing at all on a 19.5"...
Fabric Joint Propshaft Lengths
16-03-2018, 06:35 PM
Firstly not saying David K is wrong in that BP 73 and BP 93 are both 19.5" long, as who can be 100% and I suppose is why we share info
I found the prop with the part number it is hard to read but belive it is 7087 A1 so BP 73, forgot to measure it IMG_7683 (002).jpg (Size: 50.4 KB / Downloads: 60) Also had a look at the index cards and noticed that the part number for BP28 is hand amended to the same as BP93. Does this mean they are the same length?..... Should I just give up....
16-03-2018, 06:50 PM
well observed!
With the length of the carden socket being 3" or so, then one might assume that 1/2" variation could allow generic use when replacement became due. Where should the carden blocks 'sit' in the joint/socket when fitted on level ground/car not weighted? Perhaps we now need to measure axle to carden joint lengths on the three types of axle. |
