Car type: Austin seven Box saloon 1935
Hi all
I am going to be traveling from Nottingham to the centenary in July and looking for the best route with a seven, you all know what I mean, has anybody mapped out a route that avoids major busy roads etc, I can do the A46 and then B roads but just checking if somebody has a better idea
Mike
When driving the Seven I set a route using Google maps and choose the cycling setting, which gives you the best roads for our cars and less chance of holding up fast moving traffic...the result is usually a quiet, relaxing route for those of us not in a hurry!
Either your suggested route via the A46, but that means negotiating Leicester city traffic, or alternatively how about the A453 and A42 to Ashby de la Zouch, the A511 towards Coalville but branch off right onto the A447 through Ibstock and Hinckley, then a short run down the A5 until you hit the Fosse Way and head south through Brinklow, Princethorpe and Halford.
Car type: Ulster replica lwb rod Yates
08-03-2022, 06:52 PM
(This post was last modified: 08-03-2022, 06:53 PM by JFaulknerUlsterRep.)
You can go via the A453 to East Midlands airport. Drive past the entrance to the airport then follow the signs for griffidam, Pegg’s green, raven stone, Ibstock, cadeby, until you get to Hinckley then look for signs for the A5 to high cross where you can then pick up the Fosse way all the way to Morton in the marsh
DONT USE THE A5 from hinckley.
sorry but the turning onto the fosse road from here is a VERY busy dual carrage way. so 70mph and plenty of idiots and lorrys. plus to turn onto the fosse from here you have to get into the FAST LANE AND TURN RIGHT. someones going to get killed in a slow car in the fast lane.
instead go throught elmesthorpe to sharnford instead of hinckley. check the map this comes out at the A5. BUT a mile before it, there is a turning on the left called BUMBLBEE lane. it joins the A5 dirrecly opposit the fosse way. it much safer to cross in the breaks in the traffic.
im sure someone can put up a map for this.
tony
... or how about taking the B4109 out of Hinckley, through Wolvey to join the Fosse Way near Stretton under Fosse? That way you cross the A5 on a roundabout at Junction 1 of the M69.
