11-10-2021, 08:33 PM
Hi Parazine
Dusturbed to read of the silver steel expereince. Presumably as supplied and not after an attempt to harden. Ground ht steel as I used is available about 60 tsi cf 40.
Hi Colin
The chrome is very thin. Used as received. I may have polished slightly with very fine paper. When exceed 1/2 inch reaming of the eye may be necessary, but some oversize often needed anyway. I gather it can be puchased as hydraulic ram rod. I much later learned that chrome plating increases risk of fatigue failure.Although baking can improve. The hydraulic rod is possibly treated.
Hi Colin
