04-06-2021, 06:27 PM
(This post was last modified: 04-06-2021, 06:27 PM by Duncan Grimmond.)
I can't find the device I had when I was a young motorcyclist in the 1960s. A handy TDC indicator which screwed into the plug hole and hex.rod marked in 1/16ths with a circlip to stop it falling in.
I know I have it somewhere, it just vaporised when I put it down on the bench...
However, I do know where the thread adapter for the plug hole is!
Throw all the precision of "degrees" in the bin, especially if you applying them to the cam pulley which isn't keyed to anything. Use some old fashioned judgement.
Put any manual advance retard mechanism to a middling position, slightly slacken the distributor clamp (but only a little), put on a robust glove, start the engine and manually swing the distributor until you get it running nicely. If you don't think that you know what that will be, if you possess a scintilla of mechanical sympathy, you will.
When it's running OK switch off, tighten the clamp bolt and drive it. The manual advance retard will tell you how to fine tune it. If you are unfortunate enough to be lacking manual advance, I'm sorry for you. What appeared to be improvements aren't always useful.
When it's running as desired lift the flywheel cover/starter motor and make some repeatable measurements/marks/count teeth and note them down somewhere safe.
Car type: RP Deluxe Saloon 1933
I too have just constructed a TDC indicator plus timing mark. In my two wheeler days I used a dial test indicator to measure the firing point, I may even modify this device to suit a dti.
I have also added a manual timing adjuster so that I can fine tune the timing on the road, it is easy to feel the best spot, then just lock the distributor in that position.
A Rubber finger stretched over the top of the top of this indicator plug also shows the firing stroke before inserting the steel rod.
Roger
Roger, with your TDC/Timing dipstick, what distance on the rod before TDC do you set the static timing to? I also used to time my 500 single motor cycle this way.
How do you guys use the TDC measuring implements?. Ive always found that they dwell considerably at the top, that is they stop moving and you can turn the crank significantly before they move again. Getting an accurate TDC involves either skill or luck.
On any engine (including when setting the valves on my steam roller) I effectivley measure the same piston displacement each side of TDC, mark the flywheel (each side) then split the difference on the circumference of the flywheel with some dividers. And bobs your uncle. A pretty accurate TDC mark.
Just the job if someone has turned the marks off your flywheel, and/or it has some non factory markings.
I have to admit, to get an engine to start an approximate TDC is probably all that is nerded and I time by ear in anycase. So its a bit irrelevant to be, but all you whallas using timing guns should really be quoting degrees before an accurate TDC mark. Not a guessdimate of where it is.
Peter,
It turns out that my static firing point appears to be at TDC, I then marked the “dipstick” and turned a distinct groove with the lathe to show TDC. I Assume the auto advance weights do the rest.
Having set my timing to “Near enough” I go for a drive to fine tune using the manual control for this purpose. My reason for using the “dipstick” is if I need to change to my spare distributor that I carry it is easier to confirm the correct settings, although now I know it is at TDC I don’t need it.
Roger
