Lucas CFR2 developments
No - sorry - it just says 'Winter' - I added in the Full as that was the way I was thinking of it at the time - though later I learnt that there was a further increase in output when the headlights were on with this enhanced set-up.
ah - good! Interestingly, it was this diagram that enabled me to properly get my head round the circling of F1-D and F2-D, both bypassed by the path of least resistance in the switch movements.
I think I may try something in a manual two pole (i.e. 1-0-2) dash charge switch so there is the full 3.0 resistance across the dynamo, and one side of the bypass switch as 'HIGH' with nothing, and one side with 0.5 ohm as 'MID'. I wonder if it's possible to get same chrome latching toggle switch as 0-1-2 so it is possible for it to be more intuitive.
.png   Screenshot 2021-04-10 at 09.12.52.png (Size: 122.83 KB / Downloads: 94)
