I think it could be very useful - a lot of good stuff like this seems to come out of America.
I carry an imperial thread file in all my cars, they have gotten me out of a hole on several occasions - but this tool does something different and yes, thread recovery was the wrong phrase but I like how bruised threads appear to be saved using it, hence my usage.
16-01-2018, 09:48 AM
(This post was last modified: 16-01-2018, 09:48 AM by Reckless Rat.)
It seems very expensive for what it is. If the cutting edges are just hardened steel i would guess that longevity would be suspect, either that or rapid wear or brittleness might result. I think you would have to be very careful using it in a hand held situation. Personally i will stick with a thread file and/or a die.
The reviews on Amazon are very mixed...
Still hoping someone may have first hand experience.
16-01-2018, 01:36 PM
(This post was last modified: 16-01-2018, 01:37 PM by Reckless Rat.)
Apparently this tool exists in two forms, the UNIBURR (part n° 1819) and the UNIBURR + (part n° 1816). The former is only suitable for mild steel, whilst the latter claims to be OK for hardened studs and stainless. The recommendation is that a very slow speed be used with pressure. The advert shows it as suitable for square bar but I am sceptical. The Amazon reviews seem about right.
It will be a very expensive experience if it turns out to be a load of tat. Caveat emptor.
Hi All, I've ordered one of the 1816 versions. When I get it I will post my results.
Erich
I am interested to hear about your experience with it Erich.
I've done a bit more research and there seem to be a couple of others with the same essential design. There also maybe bootleg versions which could explain the poor reviews. I'm not buying on ebay or Amazon for these, but going through Tacoma Screw Products. Hopefully that means I'll get the real deal.
Erich
