12-12-2019, 03:24 PM
(This post was last modified: 12-12-2019, 03:25 PM by Chris KC.)
Have you considered hot bending Rob? It's not a walk in the park but having done an Ulster tailpipe last summer I could talk you through it.
You'd need a pattern of course, either way.
Thanks, Chris, that's kind of you, however, I have nothing to go on at the moment, although my Flexi pipe works well would like the proper thing in place just from the aesthetics alone. may call on you Chris at a later date for some instruction once I have good template. I appreciate your kind offer at this stage. I hope all is well at your end.
Regards Rob
No problem Rob. Chris Gould is your man if you seek a pattern.
Forgot to say the 'ickle Nippy looks great!
Thanks, Chris, didn't know that re C.Gould, does he have a contact number?
Rob
All I can say is few people know more about Nippies than Chris, and he has often been kind enough to send patterns for fiddly bits when other sources failed, I'm sure he'll be able to set you on the right track.
I'll p.m. you with contact details.
