  • 4 Vote(s) - 3.75 Average
Sales & Wants Section - Please Read
Welcome to the Sales and Wants Section.
It would be greatly appreciated if advertisers would remove their adverts once they have been fulfilled. This will help prevent further enquiries.
This is easily done by opening the thread and deleting your original post.
It is quite understandable that this step may be forgotten, and to help keep adverts relevant, the section is now set to hide adverts after 20 days of inactivity. If you want to keep your advert, simply add a reply, and this will reset the 20 days.
If your advert has disappeared and you want it back, this is easy to achieve, as outlined below.
Having selected the 'Sales' or 'Wants' section you should have a similar view to that shown below. To show older adverts use the drop down box circled and select the period you wish to view, then hit the 'Go' button to the right. This should reveal more adverts, and to return your thread to the top and restart the 20 days, simply post a reply. Don't worry, the next time you select the same forum it will return to the default 20 day view.
Wanted cylinder block not sleeved. Ideally no more than +40 overbore.
        for sale    Stainless manifold for 1 1/4" SU carb .    Inlet angles up into port for straighter flow  ,  bung for oxygen sensor for best  carb  tuning  ..    STEVE 520 591 6318  USA scahandyguy@gmail.com
for sale , 2 carb custom manifold           Stainless steel , NO  CARBS USA 520 591 6318 STEVE scahandyguy@gmail.com
.jpg   DSCN3535.JPG (Size: 126.67 KB / Downloads: 637)
.jpg   DSCN3536.JPG (Size: 126.49 KB / Downloads: 638)
.jpg   DSCN3537.JPG (Size: 127.44 KB / Downloads: 637)
Enhancing Residence Price By Substituting Roofs Before a Sale
Replacing roofing can greatly enhance the worth of properties before putting on market. Potential buyers often look for properties having modern or pristine roofing, because they view these as a sign of overall upkeep and diminished future costs. A new roof can turn a residence more appealing and garner an elevated value in the market. Spending into roof upgrades turns into a wise plan for sellers aiming to maximize their return on investment.
By way of a case to consider An property owner in a coastal region opts to renew their covering before listing their property for selling. The updated roof turns the home more appealing to purchasers, causing several bids an increased final sale price.
As a situation in point An inhabitant recommends a homeowner to replace their worn covering with modern materials. The cost in covering upgrade yields benefits as the property sells quickly and with a high rate.
Dependable roof replacement services in Burgaw NC
Examining Eco-Frien a3a1_20
.gif   86.gif (Size: 9.45 KB / Downloads: 166)
