25-05-2019, 12:19 PM
(This post was last modified: 25-05-2019, 12:22 PM by Duncan Grimmond.)
I dove out of the yard today, up to the roundabout and back. As I went over a pothole there was a clunk of the diff hitting the underside, argh!
I made the same tunnel as I did on the last special forgetting that this one has a Morris rear axle. There is a flange all round the casing which stands more proud than the Austin diff and it was just catching. Cut hole, form cover and fit with clecoes and try again. Another case of operator malfunction...
