05-02-2019, 04:28 PM
Ok, apologies .
To line up the splines. I turn the engine so that the blind spline is on the top, I then put the gear box in fourth gear and rotate the box so that also is on top, I then mark the gear box output fixing so that I know if it has moved and can correct if it has. Never had a problem since using this method. I prefer engine and box out together but have successfully accomplished removing engine from gear box and viseversa .
