Car type: Ruby mk 2
Hello people
Anyone got any details for the C35M dynamo.
In particular the electrical connections.
Or any other info.
Woodrow brushes seem different to mine.
I have a case with field coils from a C35A are these the same ?
Also I think Woodrow shows a felt seal
Not fitted to mine or obvious place to fit ?
Regards
Tim
Car type: Ruby mk 2
Great pictures Dave.
The first is exactly mine.
Thanks v. Much.
I can’t get over the amount of help you get from this forum.
Car type: Ruby mk 2
22-11-2018, 11:36 PM
(This post was last modified: 22-11-2018, 11:49 PM by Tiger.)
Finally got the dynamo back together.
Tested for continuity the field coils.
Test armature segments
BUT ONLY GETTING 2.5volts at about 1000 rpm
Any ideas ?
Further to my last post.
I only have one wire from the field coils.
In the diagram there is a connection to the 3rd brush ?
Dont really understand your question.
Cant recall if dynamos have yet been yet extensively covered on the present site, so....
As diagram one end of field windings exits dynamo, the other connects to 3rd brush. (Unless someone has converted to 2 brush operation and connected the internal end directly to "earth" with the 3rd brush unconnected?)
With the brushes out of contact should be same very low resistance between adjacent commutator segments (digital meter).
To test operation, the field exit terminal and main output terminal are joined (the winter charge situation) but not to any load. Voltage to earth considerably exceeds 6. Must not be permanently operated in this state with the field linked but no battery load.
(In practice in car, the 3rd brush is usually some distance from the earth brush if ammeter ouput is not to exceed 8-10 amps, lights off. Operated as two brush currents would be excessive)
Car type: Ruby mk 2
23-11-2018, 08:41 AM
(This post was last modified: 23-11-2018, 08:54 AM by Tiger.)
Thanks Bob.
That’s a big help.
Both my cases have the same fault.
One wire missing from the coils.
I can move forward on this now.
Any info.on reinsulating and connecing field coils.
