06-10-2018, 09:22 PM
Hi is the meant to be a seal between the petrol tank and the bulkhead? I believe it is felt but not sure of the profile or size, any hints or suppliers would be great to know.
Thanks
Thanks
Chummy petrol tank / bulkhead seal
Thanks
06-10-2018, 10:46 PM
The material is a kind of felt. It is continuous " ring " which slips over the tank. Dimensions are approx. 1" wide x 1/8" thick. I wouldn't call it a seal, more to prevent fretting between the tank and the bulkhead. When it came to refitting, it was a bit of a b****r. Patience needed to get it correctly placed.
07-10-2018, 08:36 AM
so would a suitably sized rubber - stretched - rim tape do?
07-10-2018, 12:30 PM
Just the other day I purchased a roll of black felt strip with a self adhesive backing from our local Bunnings hardware. I will use it to fit the sliding window channel in the motorhome but would be a simple install on the chummy tank. It's about 25mm wide so you may have to cut it down cheers Russell
https://www.bunnings.com.au/moroday-25mm...e_p3962476
07-10-2018, 04:10 PM
Thanks for the replies, having looked on google I guess the felt between chassis and bodywork would be a useful substitute. 50mm by 3mm so would need a trim.
https://www.vintagecarparts.co.uk/catego...felt-strip |
