Car type:
"There are two types of distributor: manual advance (on the steering wheel) or automatic advance.
Ignition timing: manual distributor: points open at 11⁄2“ BTDC measured on the top of the flywheel.Automatic distributor: points open at TDC on flywheel." is on the Dorset Club Technical Sheet which is generally quite useful.
I'm just trying to get my head round this for the manual setting. Does this mean that the manual setting is set when the setting lever is fully extended to ADV?
I'm presuming the lever has a set amount of movement to Adv and R, or is there ability to tweak/optimise this? And the lower advance (than later cars) explains the difference between 1 1/2" BTDC and 1 7/8" which is quoted elsewhere for the later ones?
This topic has been laboured on many occasions. The Manual are set at full advance. If the car is not to be driven by strangers extra advance can be allowed and used primarily for experiment. For ordinary cars driven sedately many consider about 1 1/2 advance adequate.
The Manual advice wrongly repeated for the Auto in 1st Ruby handbook and repeated in many other books has caused endless confusion and needless engine stresses over the decades.
Actual characteristics of present day auto distributors is anyones guess.
My 13.11.17 post under 65 Timing covers the topic. Other posts refer more to advances for the rpm and ultimate power enthusiaits with new cranks.
Advance is very stressful of crank.
One inch on flywheel is 11 deg.
Noise is not necessarily an indicator of power.
Follow the instructions in the manual. Except aim the 1/4 mark on the flywheel with the oil pressure gauge pipe. Set lever in full advance. Set dizzy so the points are just opening at that point (for no1 plug lead).
Turn it wound till it comes round next time and check. Often the slack in everythi g means it may not be quite right.
Itll start easily when retarded, and the sweet spot will be in the range of the lever.
With auto dizzy theoretically you set at tdc. Points just opening.
No idea how far from TDC it is. Never measured it.
A very useful ready reckoner a forum member told me about is one tooth = 4.5°.
I had calculated that the A/R range would be around 24°, but checking it by using a lamp on the points and looking at the flywheel shows I have a range of about 18°.
I have concluded that trial and error is the best bet and now have the static timing set with the timing mark opposite the oil gauge take off (about 18°BTDC), with the A/R lever at its mid point (I'm the only driver).
Make sure that advancing the lever turns the distributor anti-clockwise. It's easy to get the linkage arse about face.
Car type:
04-10-2018, 09:44 AM
(This post was last modified: 04-10-2018, 09:55 AM by JonE.)
Colin - so that thus gives you manual range from 27 degrees BTDC to 9 degrees BTDC overall? (i.e. You are setting "that" point at lever mid point rather than on full advance which seems to be what Hedd is advocating?)
