14-09-2017, 08:24 PM
Thanks to everyone involved in this thread, its great to know there's always someone around to help out when you need it.
I'm going to get those diagrams printed off ready to start the big re-wire (they are much easier to follow than the later ones!).
I have a few optional extras added to my car: Indicators, SU Fuel Pump and a wiper.
They are currently wired into the IGN connector - is this the right way of going about it?
I've got myself a fuse board and battery isolator switch which will be hidden away in the glove box.
It will make me a lot happier knowing that if something does short at least its only a fuse that blows and it wont cause any fires! The isolater will be great for storage and when leaving the car at shows etc, one extra deterrent...
Got a few bits of tidying up to do before I do start the re-wire. The dash has seen better days and behind the scuttle fuel tank is some very thin aluminium that's been hacked to pieces to get the original wiring through. I'll be replacing this with some new Aluminium sheet and proper grommets in the holes
Thanks again
Danny
Thanks again
Danny
