Pin valve fixings notoriously carve grooves into the valve spring seats by fretting, albeit over a period of time.
This rather suggests that they are (or should be) made of something a little harder than mild steel.
The A7CA Website ?
This seems to be the closest to a readily updated Austin Seven Companion.
I cannot remember- was there an updated A7C issue available ?
Is there a reason why the valves cannot be modified to fit the pins the OP has?
Car type: Austin 7 1936 Ruby
Hi Peter I had a similar problem which David sorted out for me, see attached.
Good afternoon, David
Just a quick question, I have tried to fit the new
valve pins(valve pins BC108C) in my valve,s and cannot get
them to fit even in the new valves I purchased,
Question is do they come in different sizes, I can't
even press them in, although I am not sure how tight they should be, the ones I
took out I was able to just pull them out with ease.
I don't really want to use the old pins, so I am not
sure what to do, (so ask the expert)
Kind regards Tony
Hi Tony,
I am sorry that the valves I sent were not satisfactory. Because you had asked for 2 of them, I sent you a couple which I had that weren't part of a set of 8, and they must have been from an earlier batch. The quickest and easiest remedy is to drill out the holes to 7/64", otherwise please return them and I'll send you a couple of valves with correct (checked) holes.
I apologise for the inconvenience.
Best regards,
Da
I took your advice and drilled out the valve
stems to 7/64" all good now, thanks again for your advice.
Kind regards Tony.
